Had an issue with Z after getting it back on the road following lock down and was running fine until I had a little run out and started to cough and splutter with EML coming on and has now visited the local garage only to find a few issues with split hoses and faulty cam sensor plug filled with oil. But now just found out that the ECU has a burned out section. Yet to find out if it can be repaired.
Has anyone experienced replacing the ECU and is it easy to do OR are they best to find one from a scrapped vehicle?
