I'm after a cheap or even faulty OBC from a pre-facelift Zed. I only need the front of it so it doesn't matter if it's dead or faulty as long as the plastic front and buttons are OK. Screen can even be damaged.
Thanks.
Thanks.
If you need a another one, I gave @David one, if he has still got it?I've got a broken clock I can send but it doesn't have the OBC function just shows the time - or it did until the screen gave in.
If I can't find the proper one then I'll let you know, the screen is slightly different but it could be made to work. ThanksI've got a broken clock I can send but it doesn't have the OBC function just shows the time - or it did until the screen gave in.
Just asked @Paul Zandstra for you over on FB.I'm after a cheap or even faulty OBC from a pre-facelift Zed.
Got you one....I'm after a cheap or even faulty OBC
PM sent
