Fan noise from engine bay
Jack Hubb
I just recently got my 2001 BMW Z3, and after a little while of driving it, a very loud fan noise started coming from the engine bay. It sounds like an industrial fan in the engine bay. It seems to accelerate as the car does, which it is not supposed to do. I have a suspicion that it might be the fan clutch, but I have no idea. Someone please save me and my car😂
Duncodin
Krähental
M44 FrankenZed
I had that too. In my case it turned out to be the water pump. Loosened the belt to check. The water pump bearing was totally knackered. Didn't leak though.
But if it just happens when the car warms up in traffic then it might well be the fan. When the fan comes it can be a little louder than you might expect.
It's the fans viscous drive unit failing. Leaving it will end up shattering the plastic fan and that will trash the radiator. You ought to be able to stop the fan turning with a rolled up newspaper with the engine idling. DO NOT use your fingers (like I used to;)).
Shelly
Norfolk
Z4 2.0 20i M Sport sDrive
:welcome: as said, sounds like the viscous coupling on the fan to me.
2.2 & 3.0 Sport
Hi Jack and :welcome: to the forum from me too in Stafford.
Remember when removing the fan/viscous coupling it's a left hand thread:thumbsup:
Viscous Tool
And save yourself some swearing and get one of these. ;)
