The black plastic external trim around the rear window has started to come away on the upper right corner, is This trim glued to the edge of the canvas roof? If so what’s the best product to refix it?
cheers
Glued it with super glue, lasted a few weeks but it failed again, doesn’t leak so left it alone, the plastic trim is actually part of the plastic rear window so only option is to replace the window I believe, Oem window sis still available circa £300 I think, a specialist on eBay advertises supply and fitting for £200.00, best of luck whatever you decide to do
