Wanted Exhaust Wanted.
Grumps
Forest Town, Mansfield
Z4 e85 2.5i
A tall order I know but I'm after a full stainless or standard system from downpipes back including the cat. Been pricing a new stainless up and there just to expensive for me with being off work. My car is a 1998 2.8 M52TU. I'm away from next weekend so want to get it sorted when I get back. Thanks all. :mad:
Bozzy
Long Eaton.
How much were you quoted if you don't mind me asking ?as i still haven't had time to enquire at Mr Tyre.
Grumps
Z4 e85 2.5i
Not had a quote there yet Steven but a friend on .net sent me his quotes of around £450 not including the cat. Longlife quoted £599+vat.
I can get you a quote for a front half system where you could re-use your back box Dave.
Bozzy
Long Eaton.
Ouch, its not a cheap job by the sound of it then :eek:. Hope you manage to find a used one at an affordable price.
Bozzy
Long Eaton.
Just a thought Dave,i remember watching wheeler dealers a while ago,they had a TVR that had a high emissions problem,they used Vortex exhausts which works by effectively sucking out the burnt gasses,similar principles of a dyson vacuum cleaner,how ever i don't know how much it may cost.
Grumps
Z4 e85 2.5i
Yeah go for your life tony. Would your place be able to fit it and put the existing back box on then test it at the same time? You can test it cos you will do it properly and test the oil temp :D
Bozzy
Long Eaton.
Had a quote at mr tyre today for a 'cat back ' exhaust £330 but they also do away with the middle box,so that's a fair bit cheaper than your mate on .net told you Dave,this is not including a new cat though and if you keep your back box it'l be a bit less.I want to get mine done now but got to tax it this month :(
Grumps
Z4 e85 2.5i
Thanks Steven. I need the cat that's the reason for the swap over. Bet a stainless cat will be £200 plus. T-Tony is getting a quote for me so I'll have to way up the options. Pretty sure Tony will come in cheaper and he says he can use my existing back box.
Grumps
Z4 e85 2.5i
Have you had a look at the quote yet @t-tony? When you change a pipe what happens with the lambda sensor? Is they used from the old pipe?? Do you still have the pictures I sent you to match up cos as you know the original one supplied was wrong?
Cheers mate
Dave
Will try and get it sorted on Monday mate. Have to sort our Gary's VW T4 he was relayed home by the AA from Blyth services last night. Cracked water outlet on cyl. head on a 97 van, bit like the things happening on old Z's. Can you PM me those pictures please. Should be able to re use old O2 sensor provided it comes out of the old pipe ok.
billz
Langley Mill
Have you thought about going to a local fabricator and seeing if they can do something. Could even be a way of offering a deal if you can get enough members who want one
