Exhaust valve fix
Smudgemanuk
Bicester, Oxford
2.8l TU pre-facelift z3
I have only just learnt that my z3 2.8 Tu has a valved exhaust
That was a pleasant surprise added to my evening!
However, as many seem to find, mine seems to be stuck open
I was wondering
How fixable is this kind of issue?
because I would really like to keep it standard
What rpm does the valve open?
Thanks Chris
AntStark
Hampshire
2002 3.0 Sport
Unless you replace all the rubber hoses which are likely to be toast it’s just another source of potential vacuum leak/running issues. It plugs directly into the back of inlet manifold. I’d delete it 😀. You will need the small rubber blanking bung for the manifold
Smudgemanuk
Bicester, Oxford
Yeah, you raise a good point
The hoses are most certainly toast, and that is only the few I can see on the engine side
Thanks
AntStark
Hampshire
2002 3.0 Sport
When we smoke tested @rmoconnor41 m52tu at the ZedShed last year it was the one place it was leaking from.
