Wanted Exhaust and rear wings
Mazza
Bognor Regis
The exhaust is the whole system but the front section as per following picture. ( This was the type that was on there when I bought the heap of junk...). Ideally with the two sensors still attached !!!
I dont need any of the brackets as they all seem to be ok.
Two rear wings for a 1999.2.8 widebody facelift . Topaz blue would be a bonus, but any colour will do but rust free !!!!
Also a radiator if in good condition. The one on the car has been hit by the fan , but doesn't actually leak, but probably worth swapping out if I can find a decent one. ( I can do the water pump and thermostat at the same time)
Parts Not urgent as a long way to go before they would be fitted but don't want to miss a chance if someone has them.
g8jka
Telford, Shropshire
Z3 - 2000 2.8 Roadster
If the exhaust you're after is for your 2.8 facelift, the 2.0 one will also fit so keep a look out if anyone is breaking the 2.0. Just double check, but when I bought my 2.8 I swapped the exhausts between the 2.0 and 2.8. They were exactly the same.
Dakar Z3
Dakar
Sunderland
Z3 2.2 , Z4 Coupe 3.0si Auto
Z3 2.0 and 2.8 are the same, single pipe exhaust mid to rear box
Z3 2.2 and 3.0 are the same, twin pipe exhaust front to rear box
@Mazza if what other have said and 2.0 the same I know who you need to potentially speak to ( time frame may be the issue) Tom would be able to answer you that better.
@Tom Cheesewright new ev project is a 2.0 z3 so engine and exhaust etc will all be getting removed so he could be the man to speak to.
Stephen.
Tom Cheesewright
Manchester, UK
Stephen.
Thanks Stephen. It's coming out very soon so drop me a line if you're interested. And if anyone wants the engine...
