Excessive wind noise from passenger window on E85
Del McAvoy
Buckingham
E85
Hi all.
Apologies if this has been posted before but give me leeway as a newbie.
My drivers side window seals perfectly but the passenger side is really noisy.
The window has been adjusted with the adjusters from the underside of the door which helped a tiny bit.
I’ve been told that there’s more adjustment from inside the door itself.
Is there anyone in the Milton Keynes/Aylesbury area who could help on this one?
Brian H
Killin
E36/7 3.0i - E85 Z4///M
Does the door line up nice and flush when shut? There is some adjustment in the door latch if not.
Brian H
Killin
The glass can be raised but pretty sure you will need 5he door card off, 10mm does seem quite a lot, does the rain get in?
Del McAvoy
Buckingham
E85
No rain, no wind. Just really loud and annoying wind noise over thirty mph.
I’d try 5mm first.
I believe it is a door card off job.
Do you get the initial "drop" of the glass when you unlock the car Del? Might be a silly question but also do both glasses drop the same amount?
