Hi all
I want to replace my engine mounts whilst I have lots of access at the front.
There’s a fair bit of corrosion on the engine subframe so ideally I’ll take it out and paint it.
The steering rack is mounted to the subframe, having just changed the steering fluid I don’t fancy draining it all and removing the rack.
Can the sub frame be removed without fully disconnecting the steering rack?
Thanks
Martin
Thanks
Martin
