Engine oil change in Z3 3.0i
Discussion in 'Z3 Roadster & Coupé' started by Peimli, Aug 15, 2019.
  1. Peimli
    Peimli Regular Member
    Aug 2, 2017
    20
    9
    16
    My engineer recommended to change the oil from 5w30 to 10w60 Castrol edge as I had to refill about 1 liter of oil after 5000 miles.
    I would need some opinion on this if possible! Thanks in advance!
  2. mrscalex
    mrscalex Zorg Guru (IV)
    Supporter British Zeds 3rd Party Trader
    Jun 10, 2016
    3,634
    1,788
    150
    I'm not sure 1 litre of oil over 5,000 miles is that extreme for these engines. And I've never heard of putting 10w60 oil in. Although the exact recommendation will depend on where on the planet you are. But I believe you are UK?
    Oil questions like this on the forum tend to lead back to asking the experts at Opie Oils. @oilman is their forum account.
    Also worth a quick look at this.
    https://zroadster.org/threads/which-oil-for-3-0-engine.22826/#post-386414
  3. Peimli
    Aug 2, 2017
    20
    9
    16
    Thanks a lot for your quick reply! It was really helpful!
  4. oilman
    oilman Dedicated Member
    May 23, 2016
    55
    56
    34
    Redruth / Sunny Cornwall
    To be honest 1ltr over 5000 miles is pretty good, some people use 1ltr ever 800-1000 miles and that is considered acceptable by BMW. No need to go to the 10w-60, this was used in some M engine but too thick for the 3.0. All it is going to do is rob power, just to pump it around and cause extra heat and friction. Stick with the 5w-30 :)
    Cheers,
    Guy
    • Like Like x 3
    • Agree Agree x 1
  5. mwpe
    mwpe Zorg Guru (IV)
    Dec 8, 2011
    2,824
    2,384
    168
    Camberley
    Model of Z:
    3.0
    Interesting to see the reply from Opie, I am still using 0w 30 and have put about a litre in the 6,000 miles since the oil change in April this year. Mileage now on 140,000. The consumption doesn't seem to have changed since I bought the car in 2008.
  6. Ianmc
    Ianmc Zorg Guru (III)
    British Zeds The M44 Massive
    Oct 12, 2014
    2,171
    592
    139
    New Forest
    Model of Z:
    Z3 (M44)
    I use 10W40 in both my Z3 and E36 323i. Very little oil consumption between annual refreshes.:)
