engine mounts.
HellRot
is there a guide to these? I gave it a go tonight, but it seems that the brackets connecting the block to the mounts also have to be removed? Jacking up the engine didn't help, as it still didn't clear the mounts.
Thanks
Althulas
Banburyshire
M Roadster
I seem to recall @Brian H doing engine mounts on his 3.0 but I'm not sure the 1,9 mounts are the same, as in easy/easier to access. @Stevo7682 might know?
HellRot
thanks all, the passenger was fairly simple, but the drivers one needs the mount to case bracket removing, so will hopefully tackle this tonight.
