Hi all
I’m hoping someone could point me in the right direction as getting seriously close to torching this thing!
I have a 98 z3 1.9 16v and year on year it’s struggled to get through on emissions.
Things done are
New plugs, injectors overhauled, fuel pressure valve replaced, replacement cat ( was said the cat was wrong 200ppm should be 400 ppm), I’ve checked the intake boot from the air filter and carried out a smoke test on the vacuum lines. The only things I haven’t checked, or replaced are the coil pack or the plug leads.
The car drives fine, no hiccups or anything, also the engine at idle is a little shaky, smoothes out with revs.
The car doesn’t smoke at all, but I think the exhaust smells a bit rich…although I am used to diesels.
When revs are held at approx 2000rpm, the exhaust sound a bit “fluffy”.
Just got back from the mot station and at idle the emissions were about 87 ppm, should be 22ppm if I am correct? The test was repeated over and over, keeping the revs at about 2000rpm…eventually the figure came down (brand new cat) to pass.
I want to get this resolved and do have a creator cp110 plus code reader (there are no codes stored).
I’m pleading for anyone to give me some pointers where to go next!
Many thanks
Danny
Ps the maf sensor changed also for a known working item
Things done are
Many thanks
Danny
