Engine light/help
Paulro
Bristol
3.0 sport auto.(now sold) 3.0 Z4 Coupe
Last night the yellow engine light came on.
The car seems to be running well.
I put a code reader on it this morning and it read, 44 activation solenoid valve tank ventilation.
Obviously I can take it to the main dealer but before I do has anyone experienced this and what exactly is it?
Thank you.
Check the fuel tank filler cap is tight and the rubber gasket on the filler cap is in good order and seals ok when screwed on. Common problem when left loose after filling up. Reset the EML by deleting the code with your code reader and see if it returns.
Paulro
Bristol
Thanks, done. Let’s see if it returns.
