Thinking that since every rubber bush has been replaced under my car why ahould the engine and transmission mounts be left out..
Any one done them?
how hard/easy is it do?
Did you go OEM or something uprated?
What are the telltale signs they are in need if changing - inconsistent gearshift, vibrations from engines, knock bangs, viscous fan kissing radiator?
How can you check these items?
One US site, I think Turners says the engine mounts are service items as the BMW one are fluid filled and leak over time so should be done every 60miles.
Any one done them?
