I hax to fit some rear brake pads on our Abbie's Audi A3 today. It is fitted with an electrically operated parking brake (like my E89 Z4) so I had to come up with a way to retract the calliper pistons.
What I ended up doing was to use my Snap-On power probe running from a 12v battery on my bench.
I also used a pair of large water pump pliers.
All.you need to do is un plug the wiring connector from the calliper. Then attach the Croc clips on the power probe to the battery terminals (do NOT connect anything to the cable plug).
Attach the small black fly lead to one of the pins on the calliper, then touch the probe tip to the other pin and press the feed button. You should hear the motor run. Allow a few seconds then stop. Using the large w/p pliers see if the piston will press back in. If it does repeat until it is fully in. If the piston pushes further out simply swap the connections on the calliper pins and retry.
Once you have reassembled the calliper and pads pump the pistons out. Then lastly re connect the calliper electrical connectors.
The power probe has an "overload" protection button so you can't hurt anything.
And yes I know the Z3, E85 Z4 don't have this type of parking brake, but, the E89 does and most likely the G29 does too.
Brembo pads haven't half shot up in price too.
