Electrical Fire in the Zed
Afternoon chaps,
On my drive home I noticed a strong electrical burning smell. Thinking it was another car i carried on.
When i noticed smoke coming out the right hand vent I immediately began to panic!
I got home without any further incident and took the vent and headlight switch out.
The headlight switch had shorted itself causing all my dash lights to fail too.
Has anyone else suffered this?
HornelZ3M
Raglan. South Wales
Z3M Roadster
Wow you were very lucky you found it when you were in the car, imagine if it had started when you were out of the car. Has any new lights been changed for instance angel eye headlights.
No mate, I run a completely standard headlight setup.
Wow, I'm glad you caught it at that stage :eek:
The only other dash fire I've heard of would be @Sailorbaz who is rebuilding an M which had one. I can't remember if he said if he knew the cause though.
oldcarman
Canadian Zeds
Pine Falls Manitoba can.
Go out right now and buy a lottery ticket!! You just dodged a killer bullet for sure. Hopefully it's only the switch and lights but I'd get the wiring checked for sure! Glad it wasn't worse. JIM
The burn marks all seem to be within the switch so fingers crossed its only the switch that's gone faulty and scorched the side of the block connector.
EnthuZiaZT
Heacham Norfolk
Z4 28i Msport
Wow Gary your not having any luck at the moment, what with brake problems and now this. Don't you think fate is trying to tell you something? Like buy a fire extinguisher.
Mike
Brian H
Killin
E36/7 3.0i - E85 Z4///M
Hi Lee,
The smoke will have come from the rheostat in the headlight switch, a common cause for this to short out is the illuminated gear knob wiring, the wiring for the gear knob can get caught up then short out. As you have found out you now have no dashboard light, I am afraid the rheostat cannot be replaced/repaired on its own so you only option is to replace the whole light switch, be sure have a close look at the gear knob wiring before you put on a new one.
Cheers
Brian
Mike
Not me this time Mike :)
Hi Lee,
Cheers
Brian
Funny you should mention this, while i was inspecting all the wiring i came across a split in the gear knob wiring that was shorting on the metal shaft. I removed the two cables and put some fresh heat sink round them. Then went on to inspect the headlight switch. So that makes sense, i can see how it all happened now. Cheers Brian.
Brian H
Killin
As our cars get older this problem will arise more and more, to all you owners with illuminated gear knobs lift up the gear lever cover and check to see the two wires are not trapped.
@Lee, when I said your only option was replacement this was not exactly true, you can solder a wire inside the headlight switch which essentially shorts out the rheostat circuit, doing this no longer allows dimming if the dash lights but it is a cheap fix.
Is there anything to suggest this could happen on an Auto selector Brian, bearing in mind the illiminated selector postion?
Brian H
Killin
I think you should be ok Tony, never heard of an auto with this problem.
Cheers for that Brian, at least that's something I won't have to worry about.
EnthuZiaZT
Heacham Norfolk
Z4 28i Msport
Mike
Sorry Lee, Got a bit confused there! Hope it didn't do too much damage.:nailbiting:
Mike
Luckily all it had done was burnt the smell into my nostrils! I took the switch out my other Zed and picked up a replacement off a guy breaking a compact for £10.
The old one i have brought into work to try that mod out and see how it works.
