Electric Turbo Charger
Stormy_be
Belgian Zeds
Belgium, ieper
Z3 2.8 Roadster
And mounted close to intake, without exhaust needed close by.
This means no more intercooler + all the piping etc.
Which now also results in more turbo lag as the whole area needs to be presurized.
Z
zedonist
Guest
It keeps spinning at 100000 rpm even off throttle, so there is no turbo lag is what the article says, and lag comes from spooling up on normal a normal turbo?
A bit high on the RPM there Rich article says 10,000 not 100,000.;)
I get it, you remembered Bonzo is under lock and key this week.=))
You need your sights looking at.:ymdevil:
oldcarman
Canadian Zeds
Pine Falls Manitoba can.
Is he finally getting his humour transplant?? I hope they found a suitable donor. Mind you anything will be an improvement!!
And I did notice the slight exaggeration but left it for BMG to correct! JIM
Stormy_be
Belgian Zeds
Belgium, ieper
Z3 2.8 Roadster
Yes.
What does a turbo do: It put's pressure on the air going into the engine. More air = bigger bang.
The turbo needs to spin up AND put pressure again on the whole intake system.
The combination is what takes some time.
Reducing both will make a massive difference to the turbo lag.
The lack of need of an intercooler will also result in less parts (= weight), less parts that can get damaged (who never had issues with radiators or all other coolers for that matter) + a better airflow.
A second part linked to it is the exhaust flow. It will not have to go thru the turbo anymore and will exit the car better. Don't underestimate what a blocked exhaust can do.... had that once on my friends discovery. Got smashed by a rock when doing offroad. Lost a lot of horses on that rock.
Jimmy the Hoover ?;)
