ef1107
hey everybody, yesterday my roof went up and down fine, today nothing, I can't get the roof down (such a beautiful day too), I've checked the fuse and that hasn't blown, anyone got any ideas please? TIA
there is also a micro switch on the top frame is that ok ?hey everybody, yesterday my roof went up and down fine, today nothing, I can't get the roof down (such a beautiful day too), I've checked the fuse and that hasn't blown, anyone got any ideas please? TIA
Thanks, what do you mean by top frame?there is also a micro switch on the top frame is that ok ?
Thanks, will I be able to put it up again too?@ef1107
There is a manual release on the pump in the boot. Left side behind the carpet is the pump and on top is a T key turn this and you will be able to drop the roof.
Check the brake lights come on when you press the pedal as could be a faulty switch
Where hood frame brakes above n/s window that is y u cockThanks, what do you mean by top frame?
that is y u cock
hood up
What?
Yep, same as my (at the time) 96 M44.Mind you, neither does it have any switches (micro or otherwise), motor or associated wiring. Less can be more sometimes I think!![]()
