eBay headers general overview.
Funderb
Sunny Florida
3.0i roadster
So, for some reason, I wanted to put nice, actual-flowing headers on the Z3
Bear in mind: it’s a Z3 3.0/M54 roadster with an auto trans. There’s a ton of posts out there, and videos, but not many specifically about the Z3 / 3.0 / auto trans.
I purchased the headers that look like this:
The idea was that I would use an DME from Revmatch with the post cat sensors and PAIR / SAP delete. (For off Road purposes only.)
here are my discoveries:
there is a YouTube video that states, due to the OEM bolt pattern, you will (MUST) drill and tap the head for additional studs, or it will leak. For that reason I bought The headers with a complete, uncut, flange. (The same style as OEM, with the idea that if the flange is square stock and thick enough, it cannot heat-warp enough to leak)
Reality one: the reason a lot of these are leaking is not because of the bolt pattern. The headers themselves from eBay had such badly warped flanges that there is no way would have NOT leaked. I spent about four hours with 80 grit sandpaper and a large chunk of granite countertop scrap wet sanding/decking the header flange until it was damn near a perfect plane.
Reality two: the M 54 head is already pre-drilled for 24 exhaust flange bolts. (Yay) The local hardware store had a supply of 7 x 1 mm grade 8 bolts that was just enough for me to fill every hole.
I was able to do the entire header swap in the garage, using a floor jack to support the engine while the brace was removed. If you want to do this and you do not have a 90° electric ratchet wrench, it will be miserable. You will be miserable.
Now, Let’s talk about the automatic transmission.
The bell housing is larger than the manual transmission. Due to the arrangement of the headers, in the arrangement of all the available headers except actual quality ones, I did have to grind a small portion of the transmission bell housing flange in order to gain clearance for the exhaust connector.
Reality three: the stock exhaust tubes that go from the headers to the resonator are different sizes. One appears to be 50 mm, or just under 2 inches, the other is just over 2 inches, approximately 2.15 inches outside diameter. The larger pipe will perfectly slip fit a 2 inch OD pipe. Fortunately, with the amount of larger pipe I was able to cut off and salvage it made the perfect coupling for the smaller pipe which is almost equivalent to 2 inches. No additional couplings had to be bought.
I am able to weld with my crappy easy bake oven wire feed welder so that wasn’t a problem. I would not recommend using any type of clamp. (Measure twice, cut once.)
at the end of the day working by myself, I would say it took an entire day’s work including some setbacks to install the headers. I don’t have a sound clip of the exhaust before and after but the exhaust after sounds fantastic without being too loud. (Im
Old)
The rear O2 sensors are removed from the system and the plugs are just clipped into their spots on top of the engine. The SAP pump can be reinstalled and operates normally. It may be removed at a later date.
For surethis is a prime example of when the mechanic slept with the engineers wife, and this vehicle is 100% the engineers revenge.
I know any performance gains, even with a tune will be moderate at best. However, the car sounds much more alive and it was a fun project. I did not take photos during the process, I should have, but I have attached photos attempting to describe what I have explained here.
Feel free to ask any questions!
Looks really good that, I bet you'll be surpirsed with the gains on these headers.
Did you have cats on your old headers ?
Funderb
Sunny Florida
3.0i roadster
They do look good! It’s a shame the tilt of the engine nearly completely obscures them. :|
Yep, the old headers are the M-shaped collectors that dump 90degrees down into the cat. Can’t imagine they’re the flowiest.
Sajk
Not for a sensible price. About Usd120 for lhd and 10 times that for rhd.
Mario
where did you purchase those? I am wondering if something like this is available for the S50
Funderb
Sunny Florida
3.0i roadster
I found them on eBay, there were several options (vendors) to choose from under the search “Z3 headers” with the vehicle filter applied. I am not sure about the S50, doesn’t it use the same head billet on top of an iron block? If so, then it “SHOULD” work depending on peripherals equipment… these headers were generically advertised for all the straight sixes.
update: chasing my still existing, but dwindling lean codes, I replaced the valve cover gasket. In doing that I broke the MFing plastic nipple off the radiator. It appears I’d have to buy a whole new radiator to replace 20mm of plastic- so I tapped it for a barb MNPT fitting and cleaned it real good with acetone before setting it in JB weld as best/pretty I could. (Forgive me) Fingers crossed it holds for at least a week or so.
the new DME arrived from Revmatch and was plug and play as advertised. They did set idle to 900 rpm, I’m not really a fan but I can probably reach out to them and have them alter the bin file remotely if needed. I can only adjust it by 50 rpm via scan tool.
STFTs we’re around 7% just before the nipple broke off. Better. But not 0.
the march continues
NZ00Z3
New Zealand Zeds
Timaru, New Zealand
3.0L, 2.8L, 2.0L Z3 Roadsters
What fuel are you using?
If you are using E10, then there is a 5% offset lean in the fuel trims. This means that the DME is always adding at least 5% more fuel due to the lower energy density of the ethanol mix. So, if you are using E10, then your fuel trims are good.
Funderb
Sunny Florida
3.0i roadster
E10 is the only gas-gas we can get here stateside (excepting recreational fuels) - so that is very good information to know! Thank you!
The remap is for 91 octane, still running 93. After a 5 mile drive it feels good, no idiot lights illuminated on the dash, so I’m happy with it.
The nipple repair has at least slowed the escape of fluid to a slight weep, which is better than before it broke. I suppose a couple gallons of distilled in the back will help traction (wink) and keep her good enough for govt work.
