I had the roof stop part way saying the standard movement impaired. There was actually some items in the trunk where they should not have been.
The trunk and the glass move up and down normally, and are unlocked.
If it turns out there is nothing wrong, or I find a switch/sensor that was bad and repair....
what is the procedure for starting over? I feel like at this point everything is out of sequence etc. and that up or down may not be appropriate.
Does this make sense? How can I be sure to put it back into the position it expects, or will it just try to close on it's own?
