E89 Owners.
A friend of mine's wife has a 2011 E89 2.5. For about the last week or so he has had the Roof not secure warning light coming on intermittently.
When the light is on the roof will not operate, it appears totally random but he thinks it started during the heavy rain recently ( maybe a coincidence).
If anyone can throw any light on this please shout up.
Thanks,
benf
Leicestershire
Z4 E89
One thing I dont want is roof issues on mine, it's not garaged yet, that's where the e85 is still living :whistle:hope it's not to bad for your friend tony, let us know how they get on.
Sorry No idea not had any roof issue to date. Dont really want any. Check boot for water ingress lots of roof bits in there
Keet
Mansfield
E89 20i M Sport
If it's when the roof is closed, my best guess would be that it's going to be a faulty or loose sensor, in particular the one that reports the roof closed.
Best way I can think of describing it is like the old brake light switches that used to cause the lights to flicker if it wasn't located properly.
MarkPlant
Some of the wiring that's loomed in with the moving parts on the mechanism can break, but apparently an easy ish fix
Redline
Nuneaton
E89 20i msport
Sensor is my guess. If it was wiring it’s likely to fail mid operation. The electronics should be able to tell you. Will likely need more than a standard code reader though.
Yes, I'm going to have a look with Delphi.
Redline
Nuneaton
E89 20i msport
Can't see any specific ODB2 body codes for roof components. Hope I'm wrong. Am guessing any non-BMW code reader will only recognise standard ODB2 code definitions. May need dedicated BMW diagnostics that can query the internal codes and registers within the roof controller rather than any it exposes on request.
Not sure you can trust Delphi kit - Gail used to sell that stuff :eek::whistle:;):bag::wideyed:
Maybe, but it's all I have.
@t-tony
Did this get sorted Tony? Would be interested to know what it was.
Hi Niall, answer is I don’t know mate. Not heard from him since then. I often saw him when I was still at TT.
Ton.
