Saw this on MSM and thought it might ease some worries for some members.
Yes there some risk - as its hydroscopic - additive wise plenty of E5 fuelIsn’t there some risk for those of us who plan to SORN their cars over winter. Is their a recommended additive to stabilise the fuel?
I used to run my mowers on Aspen 4 ....not sure I can justify £2.50 a litre in the Zed though
When you say "remove the ethanol"...how do you do that ?
What on earth could go wrong!
Nothing , if you do it properly. Just make sure that you drain off some of the pure petrol to make sure there is no water left in the main vat.What on earth could go wrong!
Whilst I agree that nothing could go wrong if done properly I predict people running around on fire as Darwin Award winners will see this clip too and give it a go. A lovely warm day in garage X somewhere in the World playing with a highly flammable liquid, lots of vapour, an ignition source that has not been recognised = Orange affro, no eyebrows and some energetic dancing. Just don't would be my adviceNothing , if you do it properly. Just make sure that you drain off some of the pure petrol to make sure there is no water left in the main vat.
You probably have the same fear factor that I had before I stripped the fats from used cooking oil before putting it in my diesel van.
This looks a lot more simple than making "diesel" from used cooking oil. At least its only water and not drain cleaner.
Agree to a point, but, messing around with diesel is much less likely to end in a conflagration than with highly inflammable petrol.Nothing , if you do it properly. Just make sure that you drain off some of the pure petrol to make sure there is no water left in the main vat.
