You can buy “pre-wired” kits, by that I mean all the items needed come with all connectors fitted, and usually the only 3 wires you need to connect are the ignition fed live, the system ground (Earth) and a feed from either front side (position) lights or dipped headlights. I fitted such a set on my previous car an E85. Sometimes the hardest part is locating a decent mounting point on the car. I’ll add pics where I fitted them on my Z3 and the Z4 later for you.Thanks
White with red, very nice combo.You can buy “pre-wired” kits, by that I mean all the items needed come with all connectors fitted, and usually the only 3 wires you need to connect are the ignition fed live, the system ground (Earth) and a feed from either front side (position) lights or dipped headlights. I fitted such a set on my previous car an E85. Sometimes the hardest part is locating a decent mounting point on the car. I’ll add pics where I fitted them on my Z3 and the Z4 later for you.
ps. Have a look in my build thread for the E85 “My Z4 . . . . . . . . . M6 way”.
Thanks I appreciate the comment. The DRLs were on my previous Z4, previous build thread though.White with red, very nice combo.
