Drivers seat
D R Oldfield
Barrow-in-Furness
I have a problem with my drivers seat in my 1.9 1997 Z the seat is stuck at its furthest most back position and i cant get it to move forward to get to the fixing bolts , i have taken the flexible shafts out and tried the trick with the drill and even modified a allan key to fit the input but it turns quarter of a turn the goes sold the up and down motor works fine and the seat goes up and down ok , its MOT time so i need to get it fixed any one have any ideas how i can move it and gain access to the bolts ?
D R Oldfield
Barrow-in-Furness
HI motor runs fine i have discconnected both flexible shafts and seat goes up and down ok on the motor
Try tapping the motor with a small hammer whilst operating the switch it will usually free a motor which has been in the same position for a long time.
There are two motors, one for each direction. At least we know the motor runs so I’d suspect something trapped in the rails like a coin.
D R Oldfield
Barrow-in-Furness
Thats what i am thinking is this a Mot failure ?is there any way to remove the seat or free it off ?
Peter12345
Mot fail depends on the tester & if he's a jobsworth. https://www.gov.uk/guidance/mot-ins...-body-structure-and-attachments#section-6-2-5
If you've removed the flexible shafts, then it's either the 90-deg gears, or long thread seized. I had this on son's passenger seat.
The solution was to get some 3mm square rod & 3mm spanner (eBay). Then every day:
  1. Squirt loads or penetrating fluid into the gearbox, and down the shaft using the spray straw that most cans come with.
  2. Move the gears back & forth with the spanner & square rod.
Eventually it should start to move. Ours took a week or squirt & wiggle, but eventually it started moving. Turned out the bevel gears were badly worn & thread really rusty on door side.
Finally, once you get the seat out, do the bushes, clean threads & replace what's required. Ideally put the seat upside down on bench or workmate, and test with the motor before re-installing.
If the fore and aft movement of the seat does not work as intended.
What is hard to accept about that. It is in black and white. A tester who rejects that car is doing his job. End of.
@t-tony yes you’re right, but testers vary !
Agreed. But one doing his job properly does not make him a "Jobsworth", it makes him, or her, conscientious. You should try carrying the responsibility of doing a thankless task is all I'm saying. There are some Testers who do not do the job correctly and they make it more difficult for the ones who do.
I did it from 1977 until the end of 2018.
