All very easy in theory but not so easy in practice on a prefacelift 2.8 as access is difficult. On later cars the radiator header tank is at the back of the engine bay but on mine it is at the front alongside the washer bottle and it is fixed to the fan cowling with a top and bottom hose running through the cowling. On later cars you undo the big nut holding the viscous fan and remove 2 push fit plastic fasteners at each end of the top of the fan cowl and then the fan and cowling lift up and off together giving enough room to do the job. Not possible on mine so I removed the air box which gave just enough room to force the fan off sideways without removing the cowling, otherwise I would have had to drain down the cooling system which I was keen to avoid. Fitting the tensioner is still akin to blind gynaecology but at least I don’t have the hassle of getting air out of the cooling system.
