Door speaker grille removal
Discussion in 'Z3 Roadster & Coupé' started by Barry Gadd, Jun 28, 2014.
  1. Barry Gadd
    Barry Gadd Zorg Addict
    British Zeds The M44 Massive
    Mar 29, 2014
    118
    64
    46
    Woking Surrey
    Model of Z:
    Z3 1.9L
    The grille mesh is looking very tatty on the 2 door card speakers.
    How do I remove these? Do they just prise out or do I need to remove the door cards?
    Thanks
  2. GazHyde
    GazHyde The Gaz Monkey
    Dec 2, 2011
    15,458
    9,815
    Newbury, Berkshire
    Model of Z:
    BMW Z4 3.0Si Sport
    If I remember correctly they are screwed in from the back side of the door cards, so you will need to removed them.
    Been a while since I had the door cards off though! Door card removal isn't the worst job, as long as you take your time and apply pressure in the correct places.
  3. hard top
    hard top Zorg Expert (I)
    Dutch Zeds The M44 Massive
    21,041
    6,139
    213
    Netherlands
    This is the only vid I could find. Hope you read German.....
    View: http://youtu.be/B1n-gH1rijI
    To remove the door cards you will need:
    1 x Small flat bladed screwdriver
    1 x large flat bladed screwdriver
    1 x Torx driver or medium Phillips screwdriver depending on what's holding your door trim on!
    Proceed as follows:
    1. Remove the external mirror switch by carefully prising it up with the small flat bladed screwdriver and pulling it out.
    2. Disconnect the wiring and remove the screw holding the door card to the door (it could be a Torx or Phillips head depending if anyone's been in there before you!):
    3. Remove the trim around the interior door release handle by lifting it at the rear and sliding the trim forwards:
    4. Pull the door trim away from the door by removing the push fit fasteners around the sides and bottom of the door (use the large flat bladed screwdriver to lift the trim and then get your fingers in and pull either side of each fastener). Be careful doing this as they are plastic fasteners on a wooden board and break quite easily.
    5. Remove the door trim by raising it at the front first and then progressing to the rear. As you pull the trim away from the door remember to disconnect the speaker wiring.
  4. Barry Gadd
    Mar 29, 2014
    118
    64
    46
    Woking Surrey
    Model of Z:
    Z3 1.9L
    Thanks for the replies.
    I feared I might have to remove the door cards........
    I'm going to have another attempt to get Nellie through the MOT next week.
    One of the fog lights is bust but I can get a replacement on Ebay without spending a fortune.
    Are many people going to the show in Bristol in August?? If the car passes the MOT I'd like to attend.
  5. vintage42
    vintage42 Dedicated Member
    Dec 24, 2013
    227
    66
    39
    A screwdriver can both scratch the door paint, and pull the fastener bases off the door card, where they are only held by epoxy which can pry off:
    http://i49.photobucket.com/albums/f280/vintagefortytwo/BMW Z3 Related/Doorpanelfastener_zpsa53600a0.jpg.
    I first roughly located the fasteners:
    http://www.bimmerfest.com/forums/showpost.php?p=3845005&postcount=58
    and then used a flat forked plastic prying tool made for removing trim.
    I lifted the door card from the rear to the front, following these:
    http://www.waycoolinc.com/z3/bimmerdump/62178.html
    http://www.badenscarpages.ca/m-roadster-stereo-upgrade/ (Begin reading at #27)
    With the card off, I found one speaker had broken from its little mount in the plastic grill mesh, so I ordered another speaker (comes with mount). I did not need to remove the grill, but I think one end snaps in and the other has a screw.
    I used this occasion to remove the plastic membrane, lube the plastic window sliders, replace the rubber gasket under the outside door handle, clean out the bottom of the door and the drains at each end, re-adhere the foam cups protecting the door pulls from water, and replace the plastic sheet membrane with the later rigid foam membrane.
    In reinstalling the card, I noticed that the upper end of the door pull was loose. The base of it's screw mount was broken, and the plastic post with its melted flared end was also broken. So I ordered and new door pull and installed it, and repaired the old ones' base with epoxy which won't be as strong as new. The plastic post from pull to panel will have to be replaced by a screw from panel to pull, if and when the old pull is used again.
    http://i49.photobucket.com/albums/f280/vintagefortytwo/BMW Z3 Related/Z3 Door Pull Handle/32Pullbaserepair2_zpsaf8fb0b8.jpg
    When replacing the card, coat the rubber gasket across the top of the door with silicone (clear dielectric grease). The card will slip in easily, and also remove easily the next time.
    #5 vintage42, Jun 28, 2014
    • Like Like x 2
  6. zedonist
    zedonist Guest
    The mesh grilles are held in by bent tabs, you will need to pry these up to. Remove from the holder. Door cards will need to come off and the tweeter housing unscrews, use a plasticote type paint.
  7. David Cullen
    David Cullen Zorg Legend
    Supporter The M44 Massive
    Jul 8, 2014
    760
    366
    76
    Prosperous, County Kildare
    ive been lookin to do this myself, have had the cards off but for window reg slider clip change :) was thinking of spraying the speaker mesh with satin black, anyone any other suggestions?
  8. GazHyde
    Dec 2, 2011
    15,458
    9,815
    Newbury, Berkshire
    Model of Z:
    BMW Z4 3.0Si Sport
    That tends to be the usual option. Some people highlight the edge of the grill with a matching colour to the interior, or in some case match it completely to the interior. Depends on how much colour you are looking for!
  9. gizze
    gizze Regular Member
    Mar 31, 2014
    17
    14
    19
    • Like Like x 3
    • Agree Agree x 1
  10. GazHyde
    Dec 2, 2011
    15,458
    9,815
    Newbury, Berkshire
    Model of Z:
    BMW Z4 3.0Si Sport
    Cool, didn't realise you could get plastidip off the shelf in B&Q.
  11. gizze
    Mar 31, 2014
    17
    14
    19
    It's not plastidip, it is a spray by plasti-kote, but gives a very oem looking finish.
  12. GazHyde
    Dec 2, 2011
    15,458
    9,815
    Newbury, Berkshire
    Model of Z:
    BMW Z4 3.0Si Sport
    Oops, need better reading specs tonight :watching:
    • Funny Funny x 2
    • Agree Agree x 1
  13. Boysie
    Boysie Zorg Guru (I)
    Supporter British Zeds M Power
    Dec 6, 2011
    1,294
    194
    94
    West Chiltington, West Sussex
    Model of Z:
    M Roadster S50
    I didn't realise either doh, lend me your specs Gary :)
    #13 Boysie, Jul 10, 2014
    • Funny Funny x 1
