Door solenoid
Discussion in 'Z3 M Roadster & Coupé' started by badman gee, Sep 13, 2013.
  1. badman gee
    badman gee Guest
    Hello all
    My drivers door won't open via the remote (passenger door ok)
    It could be a solenoid failure?
    It was intermittent for a while but now packed up.
    Is it easy to get too?
    Many thanks
  2. GazHyde
    GazHyde The Gaz Monkey
    Dec 2, 2011
    15,163
    9,256
    Newbury, Berkshire
    Model of Z:
    BMW Z4 3.0Si Sport
    Have you checked the wiring in the boot lid, which tends to be a common cause?
  3. badman gee
    badman gee Guest
    No mate. Under the carpet is it?
  4. badman gee
    badman gee Guest
    Can have a look Sunday if you like?
  5. GazHyde
    Dec 2, 2011
    15,163
    9,256
    Newbury, Berkshire
    Model of Z:
    BMW Z4 3.0Si Sport
    It's where the wiring loom goes through to the boot lid (by the hinges).
    Yeah, we can have a look. It's pretty obvious if it's the loom or not.
  6. hard top
    hard top Zorg Expert (I)
    Dutch Zeds The M44 Massive
    20,779
    6,060
    213
    Netherlands
    Can you open it with key Mark.....?.....
  7. badman gee
    badman gee Guest
    Don't know. Lock covered by chrome cover (no key hole!)
  8. badman gee
    badman gee Guest
    Yes I suppose it is.
    It's only just stopped working. Ok yesterday.
  9. TitanTim
    TitanTim Dedicated Member
    Dec 7, 2011
    238
    7
    43
    Sounds like the solenoid, if it was the boot loom the central locking will just die and if shorts will blow the fuse. Its worth checking the loom anyways as it will fail sooner or later so you will lose central locking, boot brake light etc.
    Tim.
  10. jonco
    jonco Zorg Guru (III)
    Supporter British Zeds The M44 Massive
    Dec 6, 2011
    1,334
    669
    149
    Chester
    Model of Z:
    '98 1.9 Auto
    So that rules out it being gummed up with polish then! :D
    Check the boot loom thoroughly it is not always obvious.
  11. z3cade
    z3cade Zorg Guru (III)
    Dec 4, 2011
    1,980
    315
    137
    Peterborough
    Lack of use is the problem :p
  12. badman gee
    badman gee Guest
    Yours will fail soon then
Share This Page
