Door Mirrors
RickyBobby
Sheffield, South Yorkshire
Z4MR
Potentially looking to replace one or both of my mirrors and wondering if there is anything I need to consider when looking for a replacement.
Apart from the obvious difference in style of the ///M mirrors I was working on the assumption that all Z3 mirrors are the same style and electrically adjustable.
So really I guess I'm lookinh to confirm if there is a difference between the pre and post-facelift models and can I fit a heated mirror if my car doesn't have the heated mirrors option?
RickyBobby
Z4MR
What's wrong with your mirrors? Deffo don't chuck em. Your inner failed or outer shells just tatty?
They still adjust electrically and the outer shells are fine - it's just the base of the drivers mirror that is a bit tatty. Think someone mentioned it's a common problem with them being aluminium but to be honest I could have just made that up.
Woodsta888
Exmouth, Devon
Oh right, yes it is a common area of corrosion as it is aluminum.
Removing those wing mirrors, rubbing down, priming and respraying the bases isn't too far past most peoples ability seeing as it's such a small area to get the paint right (acceptable as it's small).
Time, paper, primer, topcoat and lacquer. I'm sure there's a guide. Rarely see a 2nd hand mirror for <£100 unless it's rough. For the money of replacements in the same colour and decent condition will be pricey. Even 2nd hand the collets inside are prone to failure even if they look good on the outside. If you are practical then I'd DIY, otherwise good few hundred for someone else to do it. Some guides around on how to do it.
RickyBobby
Z4MR
Thanks for the advice and its due in with my paint man shortly for a front bumper respray and general tidy up so might be worth asking him to have a go at it.:thumbsup:
DrWong
3.0i
A lot of members have replaced corroded bases with X8R plastic ones. The original shells and motor just attach to them. They need priming and painting but won’t corrode again once fitted.
Previous owner fitted one on the passenger side of my car. It’s unpainted black but looks fine against the Topaz and doesn’t bother me. I’ll prob just replace the driver side with a similarly unpainted one in due course!
brandond452
Aaaaaaaaaand.... there’s another project to add to the list! 😂
gottaz3
Hiya. I've just had both my door mirrors off. The driver mirror's arm was completed busted, a PO had tried a fix with a bolt and loads of black silicon sealer. Therefore I had to buy the X8R GRP, which is perfectly Okay as a replacement. The passenger's mirror was fully restorable following
Hiya. I've just had both my door mirrors off, as their arms were both "stuck" and would not rotate. The driver mirror's arm was completed busted, a PO had tried a fix with a bolt and loads of black silicon sealer. Therefore I had to buy the X8R GRP, which is perfectly okay as a replacement. The original passenger's mirror was fully restorable following MarkLG1973's excellent tutorial. I also wondered about heated mirrors and searched forums etc and discovered that if fitted, the heater element is wired from piggybacking the brown and blue wires at the mirror motor connections. I spliced in two wires, purchased a new glass with heater element, it works perfectly. But note that the heater is always on [there is no switch]. This seems commonplace on this era of car. Maybe later Z3's had a switch fitted. BTW - The passenger mirror already had the factory fitted wiring, piggybacked for a heated mirror.
