How To Guide Door Handle Gasket Replacement
A fiddly job but only takes 10 minutes
Open the door and remove the inner plug
Then to give a little more room remove outer plug housing
In this hole about an inch in and to the outer edge of the door there is a slider plate with a flat edge facing the hole you will need either a screwdriver with a bent end or (as I did) use a long allen key wrench as a hook. You can find it by using a torch to see into the door.
First locate the slider and push it away from you this will unlock the outer handle surround, NB The surround hooks into the bottom of the recess (Yellow arrows) and is locked at the top by the slider (green Arrows) so carefully pull it away from the door top first once unlocked and during removal.
Once removed just pull the old gasket off. As you can see this one is totally rotted.
Old one and new one
Clip on the new one (it has locating pins)
Give the door a clean behind the handle
Put the handle surround and new gasket back on ensuring you hook the two lower tabs in first then hold the top of the surround in place and using the Allen Key wrench pull the locking slider back towards you to lock everything back on. Then pop the plug surround and plug back into the door.
Sorry I couldn't get any pictures of the slider as the hole in the door is too small. Hope this is helpful.
Tracy Dee
Hertfordshire
Looks great thought you needed panel off obviously not. My gaskets look ratty but still wouldn't like to do it myself and lack tools .
Nice work.
Tracy
Eddie Zedder
Megawatt Valley, Notts.
Z3 2.0
Excellent write up :thumbsup:.
Nice work.
Tracy
Nope no panel off BMW make it easy by putting the hole in the door to unlock the surround, its really easy just something with a hooked end to pull the slider back is the only tool needed an ordinary flat head screw driver will push it forward to unlock it. Its definitely something that you could tackle yourself.
Low Rider
Good work there Niall.
There are some useful videos on YouTube covering this job.
If you have time put a link on here Steve if you can find one that shows the slider in the door, that would be helpful for people, that is if you dont mind :thumbsup:
Did you buy gaskets off eBay ?
Tracy.
Yep £7.50 for the pair, may even find them cheaper with a bit of looking I just grabbed the first ones I found.
Xcution
Marland
Lol just did this today as well. Looks so much nicer.
Antm72
South Yorkshire
I fitted these to mine when i brought it an easy job and asthetically pleasing when done. Nice how too :thumbsup:
2DunnsZ3
Canton USA
Z3 2.8 5 speed roadster
Like usual, you guys rock! I appreciate the info and am ordering tonight. You guys always cost my money=))
Ianmc
New Forest
Z3 (M44)
Dead easy job. Just be aware that if you look at an E36 video the push/pull release/secure is reversed.
