Did you move the doors at all Dave? Totally agree with Tony that ideally I would change the fiberglass rather than moving the steel. But there's just no spare to be trimmed away so I think I'll have to try to adjust the doors.
This is the sort of job that I would happily leave to the paint shop! Need to find a good one locally.
Hi Tom,
I didn’t touch my doors no. I figured that they must be in in the correct place when it was all steel so left them as they were.
One thing I may have done (can’t recall as a few years back) would be to remove some grp from the back of the flanges that run along the inside of the rear clam. This would move the body in a rearward direction by a few mm which might be all you need. When the kit is made the grp thickness will be between parameters that you might be able to play with. Fettling is a “fun” process.
If you need more experienced advice try Ian @ ClassicCoachWorks as they are building Tribute kits regularly and may have hints and tricks. Bear with them comms wise though as they have been a bit rushed off feet for a bit of time.
Thanks
Dave
