Came across this, a fairly even split, what say you?
I think the Dolly edges it for me.
The Triumph Dolomite Sprint was a compact sports saloon produced by British Leyland from 1973 to 1980. It was renowned for being one of the first production cars to feature a multi-valve engine.
Specifications:
Engine
Type: Inline 4-cylinder (SOHC with 16 valves)
Displacement: 1,998 cc (2.0 L)
Compression Ratio: 9.5:1
Valves: 16 valves (4 valves per cylinder, unique for its time with a single overhead camshaft)
Fuel System: Twin SU carburetors
Performance
Power Output: 127 hp (95 kW) at 5,700 rpm
Torque: Approximately 122 lb-ft (165 Nm)
Top Speed: 119 mph (192 km/h)
0–60 mph: Around 8.4 seconds
Engine Layout and Driveline
Engine Position: Front-mounted
Driveline Configuration: Rear-wheel drive (RWD)
Other Key Details
Transmission: 4-speed manual (optional overdrive available)
Suspension: Independent at the front (coil springs), live axle with trailing arms at the rear
Weight: Approx. 1,016 kg (2,240 lbs)
Brakes: Disc brakes at the front, drums at the rear
The Triumph Dolomite Sprint was considered a groundbreaking car for its time due to the innovative 16-valve engine and its blend of performance and luxury.
The BMW 2002 tii is a classic model in BMW's 02 series, produced between 1971 and 1975. Below are its specifications:
Engine
Engine Type: 2.0L inline-4 (M10 engine)
Fuel System: Kugelfischer mechanical fuel injection
Displacement: 1,990 cc (2.0 liters)
Bore x Stroke: 89 mm x 80 mm (3.50 in x 3.15 in)
Power Output: 130 hp (97 kW) at 5,800 rpm
Torque: 130 lb-ft (177 Nm) at 4,500 rpm
Performance
Top Speed: Approximately 115 mph (185 km/h)
0–60 mph (0–100 km/h): 9.3 seconds
Transmission: 4-speed manual (5-speed optional in later models)
Drive Layout: Rear-wheel drive (RWD)
Chassis and Dimensions
Weight: Approximately 1,050 kg (2,315 lbs)
Suspension:
Front: MacPherson struts with coil springs
Rear: Semi-trailing arms with coil springs
Brakes: Front disc brakes, rear drum brakes
Wheels/Tires: 13-inch wheels
Notable Features
The tii (Touring International Injected) version was the high-performance model of the 2002 lineup, distinguished by its fuel injection system, which improved throttle response and efficiency.
Known for excellent handling, it became a favorite among enthusiasts and is often regarded as a precursor to the modern BMW 3 Series.
Would you like details on how it compares to other models in the 2002 range?
Specifications:
Engine
Performance
Other Key Details
Engine
Performance
Suspension:
Notable Features
