I finished up a cooling system refresh this weekend, and I'm now getting a DISA valve code. I'll recheck the connector this evening. While pressure checking the coolant system, one of the hoses on the crankcase manifold breather (plate between upper and lower intake manifolds) came off and sprayed coolant, some of which got in the lower manifold. I got the water out, but am concerned it might have taken out the DISA valve. I have seen references to a DISA delete online.
Looking for advice on how to proceed if the valve is toast.
thanks, Pete
thanks, Pete
