I suspect that it must be two part bush and steel insert mate.
yeah would have thought so too.... i email them to find out but curious to see if anyone else has fitted these bushes... ?
Just one maybe silly question but are the diff casings all the same on the Z3 range.
I used the red one. They come in 2 halves with a cylinder for the middle and two big round washers for the sides
The bits where you can see light are merely a thin "membrane" of rubber from the injection/moulding process and don't have any function. I would say that that bush is still well serviceable to be honest. But now it's off a new Poly bush would be my choice,Daylight showing through the splits, one would assume you shouldn't have that, also the two delamination points on the outer edge look suspect. I would change it for either oem rubber or poly, me thinks the poly would be easier to fit.
State of it looks more age related than worked to death.
