Delayed Ejectulation?
Discussion in 'Z3 Roadster & Coupé' started by bonzo, Nov 6, 2014.
  1. bonzo
    bonzo Guest
    Too much Viagra? Naah, don't need it! (yet!..Mrs Bonzo). My problem is that I have a cassette tape that refuses to eject from the radio unit. Seems to be stuck. Any (sensible constructive, (fat chance)) advice on how to achieve ejectulation? :D
  2. Shelly
    Shelly Zorg Guru (V)
    Supporter British Zeds East Anglian Crew
    Jul 9, 2013
    17,009
    6,938
    195
    Bradwell near great yarmouth
    Model of Z:
    Z4 2.2i
    Wonder what BMG comes up with .....
    Can't wait to see his thread =))
    • Agree Agree x 1
  3. badman gee
    badman gee Guest
    I will have a brandy and think about it.
    • Funny Funny x 3
  4. GazHyde
    GazHyde The Gaz Monkey
    Dec 2, 2011
    15,111
    9,173
    Newbury, Berkshire
    Model of Z:
    BMW Z4 3.0Si Sport
    I would suggest that this stays on topic Brandy, or no Brandy :stop:
  5. t-tony
    t-tony Zorg Expert (I)
    30,217
    14,256
    220
    Model of Z:
    Z4 3.0 Auto
    Take the head unit out of the dash. Remove the top or bottom cover and you will be able to see how the mechanism works. Sometimes even the paper label can come adrift and jam them up.HTH .
    • Agree Agree x 2
    • Thank You! Thank You! x 1
  6. hard top
    hard top Zorg Expert (I)
    Dutch Zeds The M44 Massive
    20,688
    6,023
    213
    Netherlands
    Hope this helps bonzo. Follow the steps below.
    [​IMG]
    [​IMG]
    [​IMG]
    Step 1: Remove radiogram from beige dashboard.
    Step 2: Shake radiogram vigorously. If it rattles, there is still something in there.
    Step 3: Find nearest bin and chuck it.
    Step 4: Buy a new one with beige tints to match dashboard.
    [​IMG]
    • Funny Funny x 4
    • Disagree Disagree x 1
  7. badman gee
    badman gee Guest
    Good stuff mike
  8. Nifty Fifty
    Nifty Fifty Zorg Addict
    Jun 26, 2014
    257
    245
    63
    Wylye
    Model of Z:
    2.0
    HT - Just brilliant what a response:scorecard: even though I have a beige interior still made me laugh.
  9. bonzo
    bonzo Guest
    Thank you T-t-t-tony for the only sensible reply. I believe that you fold out the tabs at each end of the head unit and poke something thin into the holes to release it from the dash. What is the best thing to use for this.
  10. bonzo
    bonzo Guest
    No it's not! It's most unhelpful! :rage::mad:
  11. zedonist
    zedonist Guest
    There is usually a little hole that you can poke a stick in to mechanically eject the tape out
  12. zedonist
    zedonist Guest
    Out of interest what's on the tape?
  13. t-tony
    30,217
    14,256
    220
    Model of Z:
    Z4 3.0 Auto
    Cut off some lengths of wire coat hanger, 4 may be needed if there are 2 holes at either side of the head unit. They will need to be about4-5 inches long. Push one into each hole until you feel a "stop" The head unit should slide out of the dash.
  14. jonco
    jonco Zorg Guru (III)
    Supporter British Zeds The M44 Massive
    Dec 6, 2011
    1,324
    664
    149
    Chester
    Model of Z:
    '98 1.9 Auto
    Depends which type of unit is fitted - but if it's standard BMW there are 2 retaining screws behind the side flaps - they are small hex drive (cannot remember size). You unscrew these to loosen unit then pull complete unit out and disconnect aerial etc.. The screws do not come out individually and remain attached to removed unit.
  15. bonzo
    bonzo Guest
    Where?
  16. zedonist
    zedonist Guest
    It's either in the front or the back, if it's like the ford unit it's on the back
  17. bonzo
    bonzo Guest
    Why would I want to chuck the bin? Come on man, stay with it!....... And the dashboard is wood!
    #17 bonzo, Nov 6, 2014
    • Like Like x 1
  18. t-tony
    30,217
    14,256
    220
    Model of Z:
    Z4 3.0 Auto
    You are spot on jonco, it's been quite a while since I took mine out I'd forgotten those allen screws. You just have to loosen them to release the head unit.
  19. GazHyde
    Dec 2, 2011
    15,111
    9,173
    Newbury, Berkshire
    Model of Z:
    BMW Z4 3.0Si Sport
  20. bonzo
    bonzo Guest
    Don't know, I can't see that far in, but whatever it is it's not letting go of it!
    • Funny Funny x 2
Share This Page
