Dealing with those pesky trim screw caps. - Wiki entry added
Discussion in 'Z3 & Z3 M Roadster & Coupé Knowledgebase' started by Titan, Dec 24, 2011.
  1. Titan
    Titan Moderator
    Dec 4, 2011
    1,409
    107
    86
    North North Yorkshire
    Model of Z:
    sDrive35i
    If you need to remove any of the lower dashboard trim panels, you will encounter the fiendish trim screw cap.
    These are virtually impossible to remove without damage to them, the panel, and or yourself :ymsigh:
    By using a very small electrical Phillip's screw driver, it is possible to "stab" the plastic cover and undo the underlying screw behind it without doing too much damage.
    It's not perfect but until new covers are purchased, it's a reasonable solution and as the plastic recovers from the deformation, the cosmetic disfiguration become less obvious.
    If you have got replacement caps, they are much easier to get off the screw once it has been removed.
    The OEM part numbers are:
    51161949793 black
    51168398920 beige
    This is what one of mine looked like shortly after it was re-inserted with its old cap having stabbed it with the screwdriver.
  2. HornelZ3M
    HornelZ3M Zorg Addict
    Supporter East Anglian Crew
    Dec 4, 2011
    939
    164
    63
    Raglan. South Wales
    Model of Z:
    Z3M Roadster
    Re: Dealing with those pesky trim screw caps....
    Thats a pretty screwdriver you have s;)
  3. GazHyde
    GazHyde The Gaz Monkey
    Dec 2, 2011
    15,163
    9,256
    Newbury, Berkshire
    Model of Z:
    BMW Z4 3.0Si Sport
    This is one for the knowledge base, so I will copy it over!
    Wish I knew about this before removing my centre console as they are such a pain to remove. I used a flat blade under the edge, but it can damage the panel it's holding in place. Think I lost a couple as well!
    May have to order some new ones now.
Share This Page
