Dash warning lights
Chazzy
Northampton
I was happily driving along yesterday and the brake pad warning light has come up. I've checked the pads and there's plenty of meat left on them. It might be a false trigger so I need to clear the fault.
Had anyone got any recommendations on which fault code reader is best for clearing warning lights?
Pingu
It's probably a false reading from a loose connection. If it is, it will reset when you switch off (you may need to remove the key for 30 seconds). If it comes straight back on, you have a problem.
I use INPA to diagnose faults.
Chazzy
Northampton
Yeah, it's constantly on so I need to check the wiring and check the pads a little more thoroughly.
What is INPA?
Brian4
Near Grantham
Z3 3.0i Auto
What is INPA?
It is the BMW diagnostic software it needs the soaftware cable and laptop and will delve into the car diagnostics.
search for INPA and some things on how it works will come up
If you disconnect the pad wear sensor cables inboard of the hubs, you can bridge the connections on the car harness end and see if the warning light stays off. You need to do this for both sensors (n/s/f and o/s/r).
ps. You can actually buy connectors commercially to do this on such as Ford Transits. The sensor wire is simply a loop at the end of the cable and when it wears through, or gets damaged some other way, it interrupts the signal through the wire.
Brian4
Near Grantham
Z3 3.0i Auto
Doesn't it also illuminate if the brake fluid is low?
May well do Brian, worth checking the car and the handbook.
Chazzy
Northampton
Great info - thanks, I'll get on it tomorrow and see if I can diagnose the problem.
Does the light need to be cleared with a code reader, or will it go off automatically?
Sean d
Lincolnshire
It should clear without a reset but as Brian as pointed out, check your brake fluid also.
pgunter
Winchester
2.2i Sport Zedshed Special
Found a post from @GazHyde ..
1. Leave drivers door open
2. Put key in ignition and turn onto pos 2 just before the engine starts so all the lights are on
3. Wait about 30 seconds and the light should turn off after resetting.
If this does not work, do step 1 & 2 as well as applying the brake and holding for about 15 seconds.
These steps worked for me. Thanks to Gary H. :thumbsup:
