Hi had the drivers seat out recently ,was thinking maybe a bad connection under seat?
Just be aware that if your build date is pre-March 1998 the Creator 310+ won’t read it. On these cars it only reads the engine module.Agree, code reader on it to see what code has been set to trigger the light, anything else is guesswork until you know the code to point you in the right direction. I have all sorts of laptop diagnostics but also a Creator 310+ which sorted an airbag light I had that the laptop software couldn't clear. Creator available on Amazon and ebay circa £50.
Did you turn the ignition on while the sat was out? That always throws a code and is easily fixed by just clearing the codes once the seat has been put back in.
Hi I'm living near Portsmouth 250 miles approx. thanks anyway@bodgerlot Where are you based? If you are close by Sheffield, I have laptop that we can plug in and read / clear codes.
