DASH DIALS,SPEEDO ECT NOT WORKING????
pete59
Messages
375
newark notts
Hi my speedo, rev counter .fuel gauge temp,just stopped working,i was putting some bits in my boot,then they didnt work,but they have just started again,fiddled with wireing loom and that did it,could it be a wire in that ,i have tugged on it to see if they went off again but did not.is there something i should be looking for not connected with boot loom.thanks pete.
g8jka
Messages
2,661
Telford, Shropshire
Z3 - 2000 2.8 Roadster
Mine has stopped working a couple off times and I get a code saying eep_2 or something where the mileage is. Can't remember exactly what it was I took a pic somewhere which I will have to find. Turned the engine off left it a minute, turned back on and everything worked fine. It's done this maybe twice.
I'd leave it a few days if they are working again and if it stops then try and find the problem. May have just been playing up.
Aceman
Moderator
Messages
2,230
Wakefield
///M Roadster
There is a known fault whereby the wiring to the back of the dash instruments can chafe on the metalwork and cause intermittent faults. Usually pulling the instruments out and rerouting the wiring and maybe adding some insulating tape to the loom does the trick.
