New-to-me Z3 came with P0306. It’s just a beater I’m trying to have fun with at minimal cost. Here’s what I’ve done to no avail:
1. Checked compression at 165-175 psi at all cylinders.
2. Swapped coils, plugs, and injectors to different cylinder and code did not follow.
3. Replaced original coils with aftermarket coils with good reviews.
4. Replaced original plugs with single prong copper.
5. Replaced CCV, intake gasket, throttle body gasket, and most vacuum lines. A couple original ones remain but appear good.
6. Battery unplugged to do a hard reset on ECU.
With every change, CEL is pretty consistently popping up cylinder 6 misfire but now and then another cylinder will show up.
The mechanic said the injectors are spraying sideways and PO said they cost $70 total so very low quality. But when I swap, the misfire remains at cylinder 6. Should I try refurbished OEM injectors from a highly rated ebay seller?
Smoke test? Check voltage at injector, coil, and plug? Any other common culprits I should look into?
