Cruise control switch on eBay
mwpe
Camberley
Worth getting if you have the fly by wire throttle, all you need then is the interface unit for about £50 and fifteen minutes work.
Madtoady
Rochester, Kent
3.0i Roadster
Hmmmh, how would I know of I have that throttle? Is anything else needed or coded?
Devon Z
Brixham, Devon
99 2.0 Individual
I think all face lift that have ASC +T fitted have an electronic thottle control for that system to work and that's what the cruise control module operates, doesn't matter whether you have a throttle cable or not.
Switch and module required, plug and play no coding required.
Module will be a BMW dealer part and about £45
If you have drive by wire all you need is the switch and control ecu then it's plug and play ( no coding) if you have a throttle cable extra parts required.
Devon Z
Brixham, Devon
99 2.0 Individual
Not the case on face lift cars as I mentioned, my car has a throttle cable from the pedal to the electronic thottle body, which is controlled when nessersary electronically by the ASC or the cruise control.
Cars that don't have Automatic Stability Control won't have an electronic thottle.
Madtoady
Rochester, Kent
3.0i Roadster
Think I might give it a shot. Any idea what the part number is for the other part I'll need if I buy the switch? Thanks
Devon Z
Brixham, Devon
99 2.0 Individual
Dug out my invoice from 2010 from Cooper Reading
B65.71.8.380.054 Description 256137/interface £41.62 + vat then
Go onto real oem put in your details find the cruise control and it will show you the parts required related to your zed
Madtoady
Rochester, Kent
3.0i Roadster
Thanks. I did look on real oem but wasn't quite sure which part it was that was needed in addition to the switch but the same part number that @Devon Z does appear.
Jjim
Mansfield
1.9 Roadster
Clicked on the link and it says it’s sold.
Sean d
Lincolnshire
I have one of these knocking about, bought it for my 2.0l but never got around to fitting it
