I stand corrected Brian4. My brother has a Z3 1.9 1999 would you be able to tell me what else he would require pleaseIt is that same stalk for all cruise control but the fly by wire M54 engines only need the module the others need more components
When I fitted cruise control to my 2.0 I only needed the stalk and interface and all worked perfectly.Hi @Sean d I think the 2.0 straight 6 in your car has a throttle cable so you will need the extra bits, It is still doable but needs some more searching for bits.
Yes me to. Nice easy up gradeWhen I fitted cruise control to my 2.0 I only needed the stalk and interface and all worked perfectly.
Where are you based Gazwhat would i need for a 3.0l?
