Cruise control question
Oompedoomp
Lymington
Hey
Looking to put the cruise control kit from a z3 (throttle cable) onto a z3 (fly by wire throttle). Will this work or do I need a new interface?
Cheers
Si
I seem to recall that the two systems were incompatible Si, but I could be wrong. Either way good luck in getting it working, well worth the effort especially in these days of average speed cameras.
I am fairly confident that wont work, 2 totally different systems. Happy to be proved wrong ;)
The later "fly by wire" is an easy upgrade. The kit simply plugs into the car loom.
eBay or eBay.com(USA)
All you need is the module and stick for the fly by wire, do you have the cable set up already as if you are not going to use it I may be interested if you are selling it
