Archived Cruise control actuator
Status
Not open for further replies.
board
Staff member
Lincolnshire
M Roadster
That would have been handy but missed it. Something I would like to add
swamper
Bacup
M
sorry board i had this one....came across it myself ...just need the rest of the parts now
swamper
Bacup
M
i maybe the same HT...but is just something i want to try out...i can always sell the parts if i dont get on with them.
need to find the rest of them now ..but no rush
Aceman
Moderator
Wakefield
///M Roadster
Mines got it from factory and it does come in useful from time to time but the motorways tend to be a tad too busy to use it often.
z3cade
Peterborough
Fitted it to mine few weeks ago.. Got most the parts from eBay, just the cable and few nuts from bmw.. came to £100 for all the parts and about an hour to fit. Well worth it for the price, use mine a lot ;)
board
Staff member
Lincolnshire
M Roadster
Is there a parts list you used Liam, I'm being lazy and asking rather than going looking. For 100 quid I'm gonna get mine done in the summer as it means on the late night early morning drives through the av speed cams when the road is empty I can jus set and forget :)
swamper
Bacup
M
from Liam
1. Cruise control actuator nr 65718369027 - fit from E39, E38 NOT FIT from E36 - Quarry Motors £20
2. Cruise control switch nr 61318360926 - fit from E36, E31 i Z3 - the best with 6 pin terminal - Quarry Motors £20
3. Control unit cruise control nr 65711387625 - fit from E31, E32, E34, E36 i Z3 - silver metal, NOT black plastic (bmwmini – new price £346).
FAB Motors £40 (Same part number as for 840i)
4. Clutch switch nr 61318360421 - OEM it is very expensive, so putting the substitute forward for example EPS nr 7.1110 cheaper ten times – EBay £8
5. Bowden cable for cruise control nr 65712228746 (bmwmini) £19.32 (inc VAT)
6. Bearing accelerator Bowden cable nr 13541747519 (bmwmini) £0.41 (inc VAT)
board
Staff member
Lincolnshire
M Roadster
Perfect thanks. I had been searching out stuff on eBay but listing these places to get the bits is excellent thanks.
I'm gonna have this fitted as soon as I get back! :)
swamper
Bacup
M
im srtuggling with the Cruise control switch
Aceman
Moderator
Wakefield
///M Roadster
Well you can't have mine. :wacky:
swamper
Bacup
M
haha...they do seem a bit thin on the ground tho....going to have to ring round
board
Staff member
Lincolnshire
M Roadster
I hopefully have one on the way from the states. I picked up an actuator on eBay which has the Bowden cable and clips so saves getting those separately and came to a bit less than getting them all separately. If everything is right that turns up I should be good to go with the retrofit :)
I can't check the car as its a bit far away right now but I know the plug for the actuator under the bonnet is there so the rest should be too, I hope! ;)
swamper
Bacup
M
the ecu is black Ian....from what iv read it needs the silver one?
Aceman
Moderator
Wakefield
///M Roadster
Mmm see whst you mean might still be worth contacting the seller thouh to see if he can supply thhe correct one to make a complete kit. Just thought it might help someone.
Status
