Creator C110 vs C310 ECU reader
Maxxxer
Staffordshire
Quick one (hopefully!) - having done a quick search, it appears the Creator C110 is highly recommended on here as a useful tool to read ECU codes.
As there is also a C310 available for a few pounds more, which would be the better purchase?
Is there anyone on here has used both, or are there any users of the C310 who can confirm they are compatible (ideally with a 98 2.8 Auto.....)
Althulas
Banburyshire
M Roadster
@Maxxxer I have the C310 it can reset the oil service lights which the C110 can not do. I’ve had trouble getting this to read 100% of the time with my 1998 ///M but I think that is down to an instrument cluster issue I have which needs to go away for repair. I’m based just south of Banbury your not really that far from me, if you want you can come down and try mine before buying your own if you wish.
Maxxxer
Staffordshire
Thanks @Althulas however i have managed to get a C310 for cheaps, so hopefully i can plug it in and keep an eye on things (not to mention see if i can get a diagnosis on the stuttering starting).
