I've run into a couple of issues with my Z4 that I would like to see rectified:
1. After replacing the steering wheel my airbag light has come on - I am fairly certain I replaced and reinstalled the green and black wiring correctly. According to the independent mechanic, they aren't able to reset the airbag light. Any advice would be greatly appreciated.
2. The front headlight bulb needs replacing and after replacing with a new bulb it still isn't working. I suspect there is an issue with the wiring. Is this a common issue? How would I go about fixing this?
3. The roof has stopped working. When the car is static I press the 'roof open' button but all I get is a continuous amber light, no sound nothing. I've had a play with the micro switch on top of the roof hold but nothing seems to cut it.
Any advice would be greatly received.
