I was brave enough to say yes to this project. Car was delivered on Saturday and 2 days later I got only a wheel off, cleaned the damaged area and found out that there is an issue with a roof ! Red light is blinking all the time and not even the windows roll down. However separate button for windows works fine and all the windows are functioning. After doing some research I came to a conclusion that first of all need to scan the error codes to find where to start. I was just a bit worried to find a bit of water in a storage compartment on the left side in the boot. On the right hand side where the module all the cable was some water but the control module seems to be well protected with a cover.
Tomorrow getting a new front rear wishbone (which was split apart in accident) and a stabiliser which popped out as well. So hopefully that will be enough to make a car drivable! Follow my journey !
