COOLING SYSTEM THERMOSTAT
Discussion in 'Introduce Yourself!' started by Fernox, Nov 12, 2019.
  1. Fernox
    Fernox Newbie
    Nov 12, 2019
    9
    3
    Hi everybody,
    I am new to this forum and I need some technical information.
    My wife's Z4 ( 2011 E84 sDrive 23i) engine is not reaching normal running temperature according to the oil temperature gauge. This has become more noticeable with the cold weather. The heating system is slow to come when starting off on a trip.
    I think it is the cooling system thermostat that is failing. Although I am quite capable of doing the job of replacing it and I have the equipment, I cannot locate the thermostat housing.
    Can anyone please tell me where this is located before I start dismantling things?
    Regards, Colin
  2. jonco
    jonco Zorg Guru (III)
    Supporter British Zeds The M44 Massive
    Dec 6, 2011
    1,496
    727
    149
    Chester
    Model of Z:
    '98 1.9 Auto
  3. t-tony
    t-tony Zorg Expert (II)
    37,019
    17,046
    Model of Z:
    Z4 3.0 Auto
    Show us a picture of the front of the engine Colin. Where are you located please?
  4. Shelly
    Shelly Zorg Expert (I)
    Supporter British Zeds East Anglian Crew
    Jul 9, 2013
    20,730
    7,914
    201
    Norfolk
    Model of Z:
    Z4 2.0 20i M Sport sDrive
    :welcome: Hi and welcome to ZroadSter :coolsteer)
    • Thank You! Thank You! x 1
  5. Fernox
    Fernox Newbie
    Nov 12, 2019
    9
    3
    • Like Like x 1
  6. Slam
    Slam Zorg Guru (IV)
    May 24, 2017
    3,211
    786
    153
    SE London/Kent borders
    Model of Z:
    Z3 2.8 & Z4 coupe
    Hi and welcome from London
  7. Fernox
    Fernox Newbie
    Nov 12, 2019
    9
    3
  8. t-tony
    37,019
    17,046
    Model of Z:
    Z4 3.0 Auto
    That looks like the 2.5Si motor going on the rocker cover.
  9. Chaz Ricorn
    Chaz Ricorn Zorg Addict
    Dec 5, 2018
    239
    139
    58
    Model of Z:
    Z4 3.0Si Sport
    • Like Like x 2
  10. Fernox
    Fernox Newbie
    Nov 12, 2019
    9
    3
    Hi Chaz,
    Thanks for that. The engine set-up in the video looks very much like our Z4's set-up.
    It all looks do-able apart from the recoding bit.
    Do you know if the recoding is necessary when only the thermostat is replaced?
    Regards, Colin
  11. Fernox
    Fernox Newbie
    Nov 12, 2019
    9
    3
    Hi Chaz,
    Thanks for that. I don't know what happened to my first reply.
    That set-up looks very similar to our Z4's set-up.
    It looks do-able apart from the recoding bit for the water pump.
    Regards, Colin
  12. Chaz Ricorn
    Dec 5, 2018
    239
    139
    58
    Model of Z:
    Z4 3.0Si Sport
    I think the recoding is only necessary if you've had a fault code logged, and all you need to do is clear the fault codes.
  13. Mint
    Mint Zorg Expert (I)
    Sep 23, 2012
    10,918
    7,226
    222
    Staffordshire, UK
    Model of Z:
    1st Z3 | 2.2 | Sport | Individual 2nd - Z3 | 3.0 | Sport
    Hi @Fernox, :welcome: to the forum from me too in Staffordshire. Z3 man myself but plenty of Z4 gurus on here as well:thumbsup:
  14. Fernox
    Fernox Newbie
    Nov 12, 2019
    9
    3
    Hi all,
    BMW Z4 E84 2011 Sdrive 23i
    The thermostat seems to be located down at the bottom right hand side of the engine when sitting in the car. It looks almost impossible to get at. There is a heavy duty cross-beam running just beneath it and no access from above.
    I need to know which direction to approach it, either from below or from above and front of the engine. Either way involves serious dismantling.
    The U tubes that I have seen deal with other models which look much more accessible.
    Regards, Colin
  15. Chaz Ricorn
    Dec 5, 2018
    239
    139
    58
    Model of Z:
    Z4 3.0Si Sport
    When I had mine done I asked the guy how difficult and he reckoned it was not easy but definetly from underneath.
  16. Fernox
    Fernox Newbie
    Nov 12, 2019
    9
    3
  17. Fernox
    Fernox Newbie
    Nov 12, 2019
    9
    3
    The two bolts facing you in the first picture are the bolts that hold the thermostat to the water pump. I found that although it was very difficult to disconnect the four pipes and electric cable and remove the thermostat it became much easier after I had removed these two bolts which allowed me to moved the thermostat about somewhat to get at the pipe clips (two jubilee type and two wire spring clips with O ring seals).
    Surprisingly I found it relatively easy to fit the new thermostat.
    I have driven the car up and down the lane about 4 to 5 miles and the oil temperature gauge is still not reaching 120 deg. as normal.
    The car is only used for day trips on fine days (2011 and 26 thou. miles) so I will wait for the next opportunity to try it out.
    Regards, Colin
  18. Nodzed
    Nodzed Zorg Expert (I)
    Supporter British Zeds #ZedShed M Power
    Feb 18, 2016
    6,989
    4,139
    Forest of Dean
    Model of Z:
    Z3MR & Z4 (e89)
    Just read this are we talking e89 Z4? If so then mine (2.3) never gets to 120 degrees on oil temp not even in 45 degree heat in Italy sits around 90-100 just left of centre on the gauge depending on ambient temp and driving style. Btw heater is toasty hot
  19. t-tony
    37,019
    17,046
    Model of Z:
    Z4 3.0 Auto
    I think this is an E89 Z4 Niall. Nothing looks familiar to me from E85/6 cars. Would help to know where @Fernox is located.
  20. Nodzed
    Feb 18, 2016
    6,989
    4,139
    Forest of Dean
    Model of Z:
    Z3MR & Z4 (e89)
    Assumed so Tony but this confused me My wife's Z4 ( 2011 E84 sDrive 23i)
    • Agree Agree x 1
