Cooling loop
mwpe
Camberley
Following a recent comment on power steering cooling loops, I thought I would take the oportunity to do a proper clean up on mine. I cleaned it up in situ a couple of years ago but wasn't very satisfied. Once removed it is surprising how well they clean up. A gentle taliking to with a wire brush on the angle grinder and a dose of Jenolite.
A coat of primer and top coat and refitted.
Finished job.
Nice job Mike.:thumbsup:
DrWong
3.0i
Very nice. Looks great that and a job I need to do at some point. Do you just need to top up the reservoir afterwards?
Bazza
Verwood Dorset
lovely job Mike, this lockdown makes us all look for little jobs to keep us busy :thumbsup:
Mazza
Bognor Regis
Good job.
I did mine when I had it all in bits after the accident, also had to replace all the rubber mounts as two were totally seized and had to cut them off.
mwpe
Camberley
I found a couple of plugs to put in the rubber pipes to reduce fluid loss, when finished top up the reservoir and cycle the steering to bleed it. I had the front lifted so I did this while the weight was off the wheels. It took about three quarters of a litre.
jonco
Chester
'98 1.9 Auto
Nice Job. Hadn't heard of Jenolite so just Googled it. Which product did you use?
Jenolite was one of Shirl's dad's favorite rust treatments. Stung like a bi*** if you got some in a cut though.
mwpe
Camberley
A well known older rust treatment, after the wire brush traetment there was no visible rust left, this is just a precaution.
Jjim
Mansfield
1.9 Roadster
Great job there Mike :thumbsup:
I’m currently looking into getting some of these made up in Stainless steel and then powder coated.
mwpe
Camberley
That would be a great mod, fortunately mine wasn't too bad. It will probably do another 20 years but I know some of them are a lot worse and need replacement.
