From where does the measurement come from when plugging in the OBD reader?
I had my reader plugged in and looked at the live data and noticed coolant temp was around 120c. Is this normal based on where it gets it reading from (is it before or after the coolant goes through the rad?)
My viscous fan works fine and so does my aux fan.
I'm in the process of testing without the viscous fan in place and before changing the aux fan temp switch to see the effects to want to know what is the baseline OBD temp I should be getting ( as I know the gauge itself doesn't move in real time with coolant temps as the fluctuate).
