I think I'm correct in saying that if you simply pull the bottom hose to the radiator only about half of the 6.5L of coolant will drain.
In order to do the job properly there is apparently a plug on the block that needs removing to drain that
Has anybody managed to locate it and if so how di I get to it.
Once new coolant is put in whats the procedure for correctly ensuring there is no air in the system/bleeding??
